Distributor Interchange Bosch To VW Number/ correct model for your bus | Forum
Snoopy Feb 6 '18
For those that don't know...  Jim Thompson organized this information years ago and has recently passed.  I am posting the information here in case his website goes down.  http://www.oldvolkshome.com/ovhignbo.htm
Snoopy Feb 6 '18
Buses
Bus & Pickup 1950-Mar 55 * 25/30HP
Distributor: VW 111-905-205, VE 4 BRS 383
Can Use:
Condensor: 02 006
Rotor: 1234 332 026 (NLA) > 1234 332 068 (NLA)
Cap: 1235 523 000 (NLA) > 1239 999 013 (NLA)
Coil: 01 001 (Blue Coil: 00 016)
Vacuum Can: None
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC Static
Advance/Retard Range: Unknown
Bus & Pickup Mar 1955-1959 * 36HP
Distributor: VW 211-905-205E, Bosch VJR 4 BR 8/1 (0231 129 019) > 211-905-205F, VJR 4 BR 25/1 (0231 129 010) > 126-905-205 (0231 178 009)
Can Use:
Condensor: 02 170
Rotor: 1237 332 072 (NLA) - Can use 04 008
Cap: 03 019
Coil: 00 001 (Blue Coil: 00 016)
Vacuum Can: None
Spark Plug: W8AC
Bus & Pickup 1960-1963 * 40HP
Distributor: VW 113-905-205A, Bosch ZV/PAU 4R2, 4R5 (0231 139 002) > 113-905-205B, 0231 139 006 > 311-905-205, ZV/PAU 4R4, 4R6 (0231 139 005) > 315-905-205B, 0231 137 031
Can Use: VW 111-905-205L or M, Bosch 0231 147 002 or 111-905-205N, 0231 137 005
Condensor: 02 006
Rotor: 04 010
Cap: 03 037
Vacuum Can: 07 015 (NLA)
Spark Plug: W8AC
Timing Set At:: 10deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum Advance Only: 10deg @ 1.3 In. Hg, 15-21deg @ 2.8 In. Hg
Bus & Pickup 1964-1965 * 1500
Distributor: VW 111-905-205L or M, Bosch ZV/JU4R3 (0231 147 002) > 111-905-205N or 113-905-205J, (Both VW Numbers are: 0231 137 005) > 315-905-205B, 0231 137 031
Can Use: VW 113-905-205A, Bosch ZV/PAU 4R2, 4R5 (0231 139 002), 113-905-205B, 0231 139 006, 311-905-205, ZV/PAU 4R4, 4R6 (0231 139 005)
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 016 (NLA)
Spark Plug: W8AC
Advance/Retard Range: Vacuum Advance Only: 5-11deg @ 1.3 In. Hg, 23-28deg @ 3.5 In. Hg
Bus & Pickup 1966-1967 * 1500
Distributor: VW 131-905-205, Bosch 0231 137 011 > 315-905-205B, 0231 137 031
Can Use: VW 113-905-205K/L, Bosch 0231 137 009/010, 113-905-205M, 0231 137 021, 113-905-205T, 0231 137 035 or 036
Points Replacement Plate Assy: VW 111-905-227B, Bosch 1237 110 139
(Note: Order 01 013 Points if using this Plate Assy)
Condensor: 02 007 - Note: If equipped w/AC use 02 069
Rotor: 04 006
Cap: 03 001
Parts Kit (Washers, Shims & Hardware): 059-998-211, Bosch 1237 070 007
Coil: 6 Volt - 00 001, 12 Volt - 00 015
Blue Coil: 6 Volt - 00 016, 12 Volt - 00 012
Vacuum Can: 07 017
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC Static or @ 800-950rpm w/strobe and vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum (Advance Only): 17-19deg @ 1.3 In. Hg, 24-28deg @ 3.2 In. Hg
Bus & Pickup 1968 * 1600
Distributor: VW 113-905-205M, Bosch 0231 137 021
Can Use: VW 113-905-205T, Bosch 0231 137 035 or 036
Replacement: VW 111-905-205AA, Bosch 0231 137 039
Rotor: 04 006 (Replacement uses 04 033)
Cap: 03 001 (Replacement uses 03 010)
Coil: 00 015 (Blue Coil: 00 012)
Vacuum Can: 07 024 (Replacement uses Bosch 1237 121 400)
Spark Plug: W8AC
Timing Set At:: 0deg TDC Static or @800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum (Advance Only): 17-19deg @ 1.3 In. Hg, 32-35deg @ 3.2 In. Hg
Bus & Pickup 1969-1970 * 1600
Distributor: VW 113-905-205T, Bosch 0231 137 035 or 036
Can Use: VW 113-905-205M, Bosch 0231 137 021
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 024 (Replacement uses 1237 121 400)
Spark Plug: W8AC
Timing Set At:: 0deg TDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Bus & Pickup 1971 * 1600
Distributor: VW 211-905-205Q, Bosch 0231 167 055 or 211-905-205S, 0231 180 001 > 043-905-205D, 0231 176 033
Can Use: VW 043-905-205D, Bosch 0231 176 033, 113-905-205AH, 0231 167 053
Points Replacement Plate Assy: VW 311-905-227A, Bosch 1237 110 064
Condensor: 02 054
Rotor: 04 033
Note: 205S/001 Distributors originally equipped with 04 021 Speed Limiting Rotor (4500rpm)
Dust Cover: 039-905-241, Bosch 1230 500 139 > 1230 500 147
Cap: 03 010
Distributor Cap Clip: 034-905-265, Bosch 1231 251 033
Parts Kit (Shims, Washers & Hardware): 059-998-211, Bosch 1237 010 007
Vacuum Can: 07 092
Spark Plug: W8AC
Timing Set At:: 5deg ATDC @ 800-950rpm w/strobe, vacuum hose(s) connected
Advance/Retard Range: Vacuum: 2-5deg Adv, 11-13deg Ret; Centrifugal: 12-16deg @ 2200rpm, 22-25deg @ 3800rpm
Bus & Pickup 1972 * 1700
Distributor: VW 021-905-205E, Bosch 0231 173 005
Can Use:
Points Replacement Plate Assy: VW 311-905-227C, Bosch1237 110 161
Condensor: 02 054
Rotor: 04 033
Note: Originally equipped with Speed Limiting Rotor 04 016 (5400rpm)
Cap: 03 010
Vacuum Can: 07 101
Ignition Wires: 09 171
Spark Plug: W8CC
Advance/Retard Range: Vacuum: 8-12deg Adv, 11-15deg Ret; Centrifugal: 13-16deg @ 2000rpm, 23-26deg @ 3600 rpm
Bus & Pickup 1973 * 1700 Manual Trans
Distributor: VW 021-905-205J, Bosch 0231 173 009 or 010 > 021-905-205N, 0231 181 005
Can Use: VW 021-905-205N, Bosch 0231 181 005
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Distributor Cap Clip: 03-905-265, Bosch 1231 251 033
Vacuum Can: 07 113
Spark Plug: W8CC
Timing Set At:: 10deg ATDC @ 800-950rpm w/strobe, vacuum hose(s) connected
Advance/Retard Range: Vacuum: 7-12deg Adv, 16-18deg Ret; Centrifugal: 9-14deg @ 2000rpm, 21-25deg @ 3400 rpm
Bus 1973 * 1700 Auto Trans
Distributor: VW 021-905-205F, Bosch 0231 173 007 > 021-905-205F, 0231 173 008
Can Use:
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Coil: 00 015 (Blue Coil 00 012)
Vacuum Can: 07 101
Spark Plug: W8CC
Advance/Retard Range: Vacuum: 8-12deg Adv, 11-14deg Ret; Centrifugal: 14deg @ 1700 rpm, 15-19deg @ 2400 rpm, 21-25deg @ 3400rpm
Bus & Pickup 1974 * 1700 Manual Trans, Dual Carbs
Distributor: VW 021-905-205N, Bosch 0231 181 005
Can Use: VW 021-905-205J, Bosch 0231 173 009 or 010
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 115
Spark Plug: W8CC
Timing Set At: 10deg ATDC @ 800-950rpm w/strobe, vacuum hose(s) connected
Advance/Retard Range: Vacuum: 7-12deg Adv, 16-18deg Ret; Centrifugal: 9-14deg @ 1600rpm, 21-25deg @ 3400 rpm
Bus 1974 * 1700 Auto Trans Dual Carbs
Distributor: VW 021-905-205Q, Bosch 0231 181 003
Can Use:
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 116
Spark Plug: W8CC
Timing Set At:: 5deg ATDC @ 800-950rpm w/strobe, vacuum hose connected
Advance/Retard Range: Vacuum: 9-12deg Adv, 11-13deg Ret; Centrifugal: 9-14deg @ 2000rpm, 21-25deg @ 3400 rpm
Bus & Pickup 1974 * 1800 Manual Trans Dual Carbs
Note: Bosch lists this application as Federal Models Only
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 115
Spark Plug: W8CC
Bus & Pickup 1974 * 1800 Auto Trans Dual Carbs
Can Use:
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 113
Spark Plug: W8CC
Bus 1974 * 1800 Auto Trans Fuel Injected
Distributor: VW 022-905-205S, Bosch 0231 170 093
Can Use: VW 021-905-205P, Bosch 0231 168 005
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 060
Spark Plug: W7CC
Advance/Retard Range: Vacuum: 8.5-11deg Adv @ 7.9 In. Hg; Centrifugal: 8-13deg @ 1600rpm, 20.5-24.5deg @ 3400 rpm
Bus & Pickup 1975-Early 1976 * 1800 (75), 2000 (76) Manual Trans
Distributor: VW 021-905-205AB, 0231 176 048, 022-905-205AB, 0231 181 012
Can Use:
Condensor: 02 074
Rotor: 04 033
Note: 0231 181 012 dist originally equipped with Speed Limiting Rotor 04 016 (5400rpm)
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 125
Spark Plug: W8CC
Timing Set At:: 5deg ATDC @ 800-950 rpm w/strobe, vacuum hose(s) connected
Advance/Retard Range: Vacuum: 8-11deg Adv @ 7.9 In. Hg, 11-13deg Ret @7.9 In. Hg; Centrifigual: 11-17deg @ 2000 rpm, 21-25deg @ 3600 rpm
Bus 1975-Early 1976 * 1800 (75), 2000 (76) Auto Trans
Distributor: VW 021-905-205AC, Bosch 0231 176 055 > 022-905-205AC, 0231 181 014
Can Use:
Condensor: 02 074
Rotor: 04 033
Note: 0231 181 014 dist originally equipped with Speed Limiting Rotor 04 016 (5400 rpm)
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 127
Spark Plug: W8CC
Timing Set At:: 5deg ATDC @ 900-1000 rpm w/strobe, vacuum hose(s) connected
Advance/Retard Range: Vacuum: 3-7deg Adv @ 6.3 In. Hg, 11-13deg Ret @ 8.2 In. Hg; Centrifugal: 11-17deg @ 2000 rpm, 21-25deg @ 3600 rpm
Bus & Pickup Late 1976-1978 All States, 1979 Federal * 2000
Note: This Distributor also fits Type 4 (412) 1974
Distributor: VW 021-905-205P, Bosch 0231 168 005 > 022-905-205S, 0231 170 093
Note: 0231 170 093 dist primarily used on California Late 1976-1978 and all Federal 1979 Models
Can Use:
Condensor: 02 074
Rotor: 04 033
Note: 0231 168 005 dist originally equipped with Speed Limiting Rotor 04 016 (5400rpm)
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 060
Spark Plug: W8CC
Timing Set At:: 7.5deg BTDC @ 850-950 rpm (Man Trans), 900-1000 rpm (Auto Trans) w/strobe, vacuum hose connected
Advance/Retard Range: Vacuum: 8.5-11deg Adv @ 7.9 In. Hg; Centrifugal: 8-13deg @ 1600 rpm, 20.5-24.5 @ 3400 rpm
Bus Calif 1979 * 2000
Distributor: VW 039-905-205C, Bosch 0237 022 009
Can Use: (Same as Vanagon Calif 80-83 Air Cooled - See Below)
Dist Hall Sender w/Parts: 035-998-065, Bosch 1237 011 050
Ignition Control Module (On Left Firewall): VW 211-905-351B or D, Bosch 0227 100 137
(Note: VW has superseded this to 191-905-351B, Bosch 0227 100 142. This unit is supposed to be heavier duty, mounted onto it's own cast iron heat sink, which is in turn mounted to the existing heat sink on the left firewall. Longer sheet metal screws will be needed when performing this superseded installation.)
Note: Will replace OE Fairchild/Telefunken Module if installed
Rotor: 04 038
Cap: 03 010
Internal Distributor Parts:
Hall Impulse Generator: 035-905-315 1237 031 053 > 1237 031 061
(Note: Very expensive by itself - cheaper to buy Hall Sender w/Parts above)
Timing Core/Rotor (Reluctor): 071-905-309A, 1231 328 032 > 049-905-309A, 1231 328 046
Pin for Reluctor: 035-905-319, 1233 101 035
Coned Spring Washer for Reluctor: 035-905-321, 1230 150 004
"C" Lock Ring for Reluctor (2 Req'd): 035-905-323, 1230 118 002
Black Plastic Hall Connector on side of Distributor: 035-905-331, 1230 329 009
Coil: 00 041
Vacuum Can: 07 163
Spark Plug: W8CC
Timing Set At:: 5deg ATDC @ 800-950 rpm (Manual Trans), @ 850-1000 rpm (Auto Trans) w/strobe, vacuum hose(s) connected
Advance/Retard Range: Vacuum: 11-13deg Adv @ 9.4 In. Hg, 11-13deg Ret @ 9.4 In. Hg; Centrifugal: 9-13deg @ 1600 rpm, 12-16deg @ 2800 rpm, 21-25deg @ 3600 rpm
Note: In regards to the Vacuum Advance - Bentley Vanagon states that there is 9-12deg Advance @ 8.2 In. Hg, even though they are the same distributors - possible discrepancy?
Vanagon Calif 1980-1983 * 2000
Can Use: (Same as Bus Calif 1979 - See Above)
Rotor: 04 038
Cap: 03 010
Coil: 00 041
Vacuum Can: 07 163
Spark Plug: W8CC
Timing Set At:: 5deg ATDC @ 800-950 rpm (Manual Trans), @ 850-1000 rpm (Auto Trans) w/strobe, vacuum hose(s) connected. Idle Stabilizer must be disconnected and it's plugs directly connected together (bypassing the Stabilizer) for accurate timing with strobe. Reconnect Idle Stabilizer when timing is set.
Advance/Retard Range: Vacuum: 9-12deg Adv @ 8.2 In. Hg, 11-13deg Ret @ 8.2 In. Hg; Centrifugal: 9-13deg @ 1600 rpm, 12-16deg @ 2800 rpm, 21-25deg @ 3600 rpm
Note: In regards to the Vacuum Advance - Bentley Bus states that there is 11-13deg Advance @ 9.4 In. Hg, even though they are the same distributors - possible discrepancy?
Vanagon Federal 1980-1983 * 2000
Note: VW 021-905-205P, Bosch 022-905-205S, 0231 168 005
Can Use:
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 060
Spark Plug: W8CC
Timing Set At:: 7.5deg BTDC @ 850-950 rpm (Man Trans), 900-1000 rpm (Auto Trans) w/strobe, vacuum hose connected. (Bentley Table on Page 28.3 incorrectly states with hose disconnected).
Advance/Retard Range: Vacuum: 8-12deg Adv @ 7.9 In. Hg; Centrifugal: 9-14deg @ 1600 rpm, 21-25deg @ 3400 rpm
Vanagon 1983-1984 * 1900 Digijet
Distributor: VW 025-905-205D, Bosch 0237 022 025
Can Use:
Rotor: 04 038
Cap: 03 010
Note: If equipped with Ignition Wires with Suppressors at Both Ends (Bosch 09 272), use 03 212
Coil: 00 041
Vacuum Can: 07 212
Ignition Wires:
If using 03 010 Cap: 09 180
If using 03 212 Cap: 09 272
Spark Plug: W7CC, WR7DTC
Timing Set At:: 5deg ATDC @ 850 rpm w/strobe, vacuum hose(s) connected. Idle Stabilizer must be disconnected and it's plugs directly connected together (bypassing the Stabilizer) for accurate timing with strobe. Reconnect Idle Stabilizer when timing is set.
Advance/Retard Range: Vacuum: 12-16deg Adv @ 10.6 In. Hg, 9-11deg Ret @ 10.6 In. Hg; Centrifugal: 16-20deg @ 2400 rpm, 21-25deg @ 3800 rpm
Vanagon 1985 * 1900 Digijet
Distributor: VW 025-905-205K, Bosch 0237 022 045
Can Use:
Dist Hall Sender Only: Bosch: 1237 010 027
Rotor: 04 038
Cap: 03 010
Coil: 00 061
Vacuum Can: 07 212
Ignition Wires: 09 272
Vanagon 1986-1991 * 2100 Digifant
Distributors:
86-90 * To VIN 25-L-060000: VW 025-905-205M, Bosch 0237 520 007 > 025-905-205AC, 0237 520 038
90-91 * Fr VIN 25-L-060001 to VIN 25-M-105000: VW 025-905-205AC, Bosch 0237 520 038 > 025-905-205AG, 0237 520 046
1991 * Fr VIN 25-L-105001: VW 025-905-205AG, Bosch 0237 520 046
Dist Hall Sender Only: Bosch 1237 010 027
Ignition Control Module: None. Ignition and Advance controlled by Digifant ECU
Rotor: 04 170
Cap: 205M Dist 86-88: 03 212; 205M Dist 89-Early 90: 03 214; 205AC Dist: 03 360; 205AG Dist: 03 368
Coil: 86-87: 00 061; 88-89: 00 074; 90-91: 00 061
Vacuum Can: None. Advance controlled by Digifant ECU
Timing Set At:: 5deg BTDC @ 2000 rpm w/strobe. Thermotime Sensor (Digifant ECU Temp Sensor II) must be disconnected when performing timing adjustment. Engine Oil Temperature must be at 80c (176F) minimum.
Advance/Retard Range: Digifant ECU Controlled: 35deg @ 3000 rpm (+ or - 5deg)
Snoopy Feb 6 '18
Type 3
Type 3 61-63 * 1500
Distributor: VW 311-905-205, Bosch ZV/PAU 4R4, ZV/PAU 4R6 (0231 139 005)
Can Use: VW 113-905-205A, Bosch ZV/PAU 4R2, 4R5 (0231 139 002) or 113-905-205B, 0231 139 006, or 111-905-205L or M, Bosch 0231 147 002 or 111-905-205N, 0231 137 005
Replacement: VW 315-905-205B, Bosch 0231 137 031
Condensor: 02 006
Rotor: 04 010
Cap: 03 037
Coil: 00 001 (Blue Coil 00 016)
Ignition Wires: 09 003
Spark Plug: W8AC
Type 3 1964 * 1500N
Distributor: VW 111-905-205L, Bosch ZV/JU 4R3 (0231 147 002)
Can Use: VW 111-905-205M, Bosch 0231 147 002 or 111-905-205N, 0231 137 005
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Spark Plug: W8AC
Type 3 1964 * 1500S
Distributor: VW 341-905-205, Bosch ZV/JCU 4R3 (0231 150 001)
Replacement: VW 311-905-205R, Bosch 0231 150 010
Condensor: 02 006
Rotor: 04 006
Cap: 03 002 (NLA)
Vacuum Can: 1237 121 179 (NLA)
Spark Plug: W8AC
Timing Set At:: Static Timing: If Pulley has two notches, it is set at the right notch which is 10 Degrees Before Top Dead Center (BTDC). If the pulley has three notches, it is set at the right notch which is 12.5 Degrees BTDC.
(Note: Models timed at 12.5 BTDC usually required high octane gasoline)
Advance/Retard Range: Vacuum: 8-11 deg Adv (approximate). Centrifigual: 15-21deg @ 4200rpm
Distributor notes: This was a unique distributor installed on the "S" Models in 1964. At first glance it looks like a Beetle 36hp "cast-iron" distributor with a push-on (not screw-on) vacuum advance unit (and it does use the 36hp points). In addition the centrifigual advance was a dual weight model, while most other VW models using centrifigual advance used single weights. Dual weights do allow for better power through all acceleration modes and it's a shame VW didn't continue it. Having owned a 64 Notchback 1500S, I was impressed at the response of this distributor throughout the powerband even when I upgraded to a fresh 1600 engine. Even though used only one year and some parts like the cap and vacuum can are hard to find, I whole heartily recommend this distributor for any carburetted Type 3 application, whether for sport or every day driving use.
Type 3 1964 * 1500S (Replacement Distributor)
Distributor: VW 311-905-205R, Bosch 0231 150 010
Condensor: Unknown
(Note: Neither VW or Bosch lists this part in any of their references!)
Rotor: 04 006
Cap: 03 001
Vacuum Can: Unknown
Spark Plug: W8AC
Advance/Retard Range: Unknown - may be the same as 0231 150 001 above
Type 3 Early 1965 * 1500N
Note: This application is up to Engine 784 309
Distributor: VW 111-905-205M, Bosch ZV/JU 4R3 (0231 147 002)
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Spark Plug: W8AC
Type 3 Early 1965 * 1500S
Distributor: VW 311-905-205D, Bosch 0231 147 006
Replacement: VW 311-905-205Q, Bosch 0231 137 033
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 017
Spark Plug: W8AC
Type 3 Late 1965 * 1500N
Note: This application is from Engine 784 310 thru 1 100 000
Distributor: VW 111-905-205N, Bosch 0231 137 005
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Spark Plug: W8AC
Type 3 Late 1965 * 1500S
Distributor: VW 311-905-205E, Bosch 0231 137 007
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 017
Spark Plug: W8AC
Type 3 1966 * 1600
Distributor: VW 311-905-205F, Bosch 0231 137 013
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Spark Plug: W8AC
Type 3 1967 * 1600
Distributor: VW 311-905-205G, Bosch 0231 137 017 or 018
Replacement: VW 311-905-205Q, 0231 137 033
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 017
Spark Plug: W8AC
Type 3 69-69 * 1600 Fuel Injected Manual Trans
Distributor: VW 311-905-205L, Bosch 0231 163 001
Replacement: VW 311-905-205AB, Bosch 0231 163 008 > 311-905-205AC, 0231 163 018
Condensor: 02 039
Rotor: 04 007 (Can use 04 006)
Cap: 03 001
Vacuum Can: 07 022
FI Trigger Points Assembly: 1230 090 000
Ignition Wires: 09 004
Spark Plug: W8AC
Timing Set At: 0deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Type 3 69-70 * 1600 Fuel Injected Automatic
Distributor: VW 311-905-205M, Bosch 0231 163 003
Replacement: VW 311-905-205AD, Bosch 0231 163 016
Condensor: 02 039
Rotor: 04 006
Cap: 03 001
Coil: 00 015 (Blue Coil 00012)
Vacuum Can: 07 022
Spark Plug: W8AC
Type 3 1970 * 1600 Fuel Injected Manual Trans
Distributor: VW 311-905-205AB, Bosch 0231 163 008
Replacement:
Condensor: 02 039
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 022
Spark Plug: W8AC
Advance/Retard Range: Vacuum: 8-12deg Adv; Centrifugal: 10-14deg @ 1500rpm, 20-23deg @ 2300rpm, 27-30 @2800rpm
Type 3 1971 * 1600 Fuel Injected Manual Trans
Distributor: VW 311-905-205AC, Bosch 0231 163 018
Replacement: Same
Condensor: 02 039
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 022
Spark Plug: W8AC
Type 3 1971 * 1600 Fuel Injected Automatic
Distributor: VW 311-905-205AD, Bosch 0231 163 016
Replacement: Same
Condensor: 02 039
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 044
Ignition Wires: 09 044
Spark Plug: W8AC
Type 3 1972 * 1600 Fuel Injected Manual Trans
Note: Bosch shows this distributor to be installed through April 1972 which may be incorrect. VW shows this distributor to be installed throughout the 1972 model year in North America.
Distributor: VW 311-905-205AE, Bosch 0231 172 009
Replacement: Same
Condensor: 02 054
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 100
Spark Plug: W8AC
Timing Set At: 5deg BTDC @ 800-950rpm w/strobe w/both vacuum hoses disconnected and plugged. When finished with timing and hoses plugged in, possible readjustment of idle to 850-900rpm may be needed
Advance/Retard Range: Vacuum: 8-12deg Adv, 9-10deg Ret; Centrifugal: 11-16deg @ 1800rpm, 19-23deg @ 4000rpm
Type 3 1972 * 1600 Fuel Injected Automatic
Distributor: VW 311-905-205AF, Bosch 0231 172 011
Replacement: Same
Condensor: 02 054
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 100
Spark Plug: W8AC
Timing Set At: 5deg BTDC @ 800-950rpm w/strobe w/both vacuum hoses disconnected and plugged. When finished with timing and hoses plugged in, possible readjustment of idle to 900-1000rpm may be needed
Advance/Retard Range: Vacuum: 8-12deg Adv, 9-10deg Ret; Centrifugal: 12-18deg @ 1800rpm, 19-23deg @ 4000rpm
Type 3 1973 * 1600 Fuel Injected Manual Transmission
Note: Bosch shows this distributor to be installed from April 1972 which may be incorrect. VW shows this distributor for North America to be installed on 1973 models only.
Distributor: VW 311-905-205AG, Bosch 0231 163 027
Replacement: Same
Condensor: 02 054
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 052
Spark Plug: W8AC
Type 3 1973 * 1600 Fuel Injected Automatic
Distributor: VW 311-905-205AH, Bosch 0231 163 029
Replacement: Same
Condensor: 02 054
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 052
Spark Plug: W8AC
Snoopy Feb 6 '18
Type 4
Type 4 411 70-72 * 1700 D-Jetronic FI Manual Transmission
Distributor: VW 022-905-205AE, Bosch 0231 172 007/008 > 022-905-205P, 0231 172 019/020
Replacement: VW 022-905-205P, Bosch 0231 172 019/020 Can Use:
Condensor: 02 054 (Superseded from 1237 330 170)
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 085
Spark Plug: W8CC
Timing Set At: 27deg BTDC @ 3500rpm w/strobe w/vacuum hose disconnected. Red Mark on the Fan/Pulley must align with the "v" notch viewed thru the access hole in top center rear of fan housing.
Advance/Retard Range: Vacuum: 11-14deg Adv, 8-12deg Ret; Centrifugal: 10-15deg @ 1500rpm, 14-19deg @ 2000rpm, 22-27deg @ 3000rpm
Type 4 411 71-72 * 1700 D-Jetronic FI Automatic
Distributor: VW 022-905-205AH, Bosch 0231 163 011 or 012
Replacement: Same
Points Plate Assembly: VW 311-905-227C, Bosch 1237 110 161
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 042
Spark Plug: W7CC
Advance/Retard Range: Vacuum: 11-13deg Adv; Centrifugal: 10-15deg @ 1500rpm, 22-27deg @ 3000rpm
Type 4 412 1973 * 1700 D-Jetronic FI
Distributor: VW 022-905-205P, Bosch 0231 172 019 or 020
Replacement: Same
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 109 > 07 140
Spark Plug: W7CC
Type 4 412 * 1800 L-Jetronic FI
Note: This Distributor also fits Type 2 Late 76-78 & Type 2/Vanagon Federal 79-83
Replacement: Same
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 060
Spark Plug: W7CC
Timing Set At: 5deg BTDC @ 900-1000rpm w/strobe w/vacuum hose disconnected & plugged. Red Mark on the Fan/Pulley must align with the "v" notch viewed thru the access hole in top center rear of fan housing.
Advance/Retard Range: Vacuum: 8.5-11deg Adv @ 7.9 In. Hg; Centrifugal: 8-13deg @ 1600 rpm, 20.5-25.5 @ 3400 rpm
Snoopy Feb 6 '18
BEETLE
Beetle 1949-December 1953 * 25HP to Eng 1-695 281
Can Use:
Condensor: 02 170
Cap: 03 019
Vacuum Can: None
Spark Plug: W8AC
Beetle Jan 1954-Dec 1954 * 36HP to Eng 1-945 526
Can Use:
Condensor: 02 006
Vacuum Can: None
Spark Plug: W8AC
Beetle 1955-1960 * 36HP
Distributor: VW 111-905-205C, Bosch VJU 4 BR 8/1 (0231 112 005) > 111-905-205F, VJUR 4 BR 8/1 (0231 115 020/040)
Can Use:
Condensor: 02 170
Rotor: 04 008
Cap: 03 019
Vacuum Can: 1237 121 113 (NLA)
Spark Plug: W8AC
Beetle 1961-1964 * 40HP
Condensor: 02 006
Rotor: 04 010
Cap: 03 037
Spark Plug: W8AC
Beetle 1965 * 40HP
Distributor: VW 111-905-205L or M, Bosch ZV/JU4R3 (0231 147 002) > 111-905-205N or 113-905-205J, (Both VW Numbers are: Bosch 0231 137 005)
Can Use: VW 113-905-205A, Bosch ZV/PAU 4R2, 4R5 (0231 139 002), 113-905-205B, 0231 139 006, 311-905-205, ZV/PAU 4R4, 4R6 (0231 139 005) > 315-905-205B, 0231 137 031
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Spark Plug: W8AC
Beetle 1966-1967 * 1300/1500
Distributor: VW 113-905-205K/L, Bosch 0231 137 009/010 > 315-905-205B, 0231 137 031
Can Use: VW 113-905-205M, Bosch 0231 137 021, 113-905-205T, 0231 137 035 or 036
(Note: Order 01 013 Points when using this Plate Assy)
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 017
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Beetle 1968 * 1500 Man Trans
Spark Plug: W8AC
Beetle 1969-1970 * 1500/1600 Manual Trans
Rotor: 04 033
Cap: 03 010
Spark Plug: W8AC
Beetle 1968 * 1500 Auto-Stick Trans
Distributor: VW 113-905-205P, Bosch 0231 115 056
Can Use: VW 113-905-205AA, Bosch 0231 115 078, 113-905-205AD or AE, 0231 167 029
Condensor: 02 021 (Can use 02 039)
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 023
Spark Plug: W8AC
Advance/Retard Range: Vacuum: 8-12deg Adv; Centrifugal: 13-16deg @ 2200rpm, 25-28deg @ 3900rpm
Beetle 1969 * 1500 Auto-Stick Trans
Distributor: VW 113-905-205AA, Bosch 0231 115 078
Can Use: VW 113-905-205P, Bosch 0231 115 056, 113-905-205AD or AE, 0231 167 029
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 023
Spark Plug: W8AC
Timing Set At:: 0deg TDC @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Beetle 1970 * 1600 Manual Trans
Distributor: VW 113-905-205T, Bosch 0231 137 036
Can Use:
Condensor: 02 007 Note: If equipped w/AC use 02 069
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 024
Spark Plug: W8AC
Beetle 1970 * 1600 Auto-Stick Trans
Distributor: VW 113-905-205AD or AE, Bosch 0231 167 029 > 113 905 205AL, 0231 146 101
Condensor: 02 039
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 138
Spark Plug: W8AC
Beetle 1971 * 1600 Manual Trans
Distributor: VW 113-905-205AJ, Bosch 0231 167 049 > 043-905-205C, 0231 176 028
Can Use: VW 113-905-205AN, Bosch 0231 167 070 or 043-905-205C, 0231 176 028
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 223 (1237 122 969) (Formerly 07 091 [1237 121 851]
Spark Plug: W8AC
Timing Set At:: 5deg ATDC @ 800-950rpm w/strobe, vacuum hose(s) connected.
Advance/Retard Range: Vacuum: 9-12deg Adv, 11-13deg Ret; Centrifugal: 6-12deg @ 1500rpm, 22-25deg @ 3800rpm
Beetle 1972-1973 * 1600 Manual Trans
Distributor: VW 113-905-205AN, Bosch 0231 167 070 > 043-905-205C, 0231 176 028
Can Use: VW 113-905-205AJ, Bosch 0231 167 049
Points Replacement Plate Assy: VW 311-905-227C, Bosch 1237 110 161
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 102
Spark Plug: W8AC
Advance/Retard Range: Vacuum: 5-8deg Adv, 11-13deg Ret; Centrifugal: 6-12deg @ 1500rpm, 22-25deg @ 3800rpm
Beetle 1971 * 1600 Auto-Stick Trans
Important Note! The listing for this distributor appears ONLY in the Bosch References and does not appear in any Volkswagen Tune-Up References, nor in their Parts Microfilms. It may have been a "Service Replacement".
Distributor: Bosch 0231 167 012
Can Use: VW 113-905-205AH, 0231 167 053 or 043-905-205D, 0231 176 033
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 083
Spark Plug: W8AC
Advance/Retard Range: Unknown - May be the same as 113-905-205AH below
Beetle 1971-1973 * 1600 Auto-Stick Trans
Distributor: VW 113-905-205AH, Bosch 0231 167 053 > 043-905-205D, 0231 176 033
Can Use: VW 043-905-205D, Bosch 0231 176 033, 211-905-205Q, 0231 167 055, 211-905-205S, 0231 173 001
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 092
Spark Plug: W8AC
Beetle 1974 * 1600 Calif Manual Trans
Distributor: VW 043-905-205C, 0231 176 028
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 114
Spark Plug: W8AC
Beetle 1974 * 1600 Federal Manual Trans
Distributor: VW 043-905-205, Bosch 0231 170 034
Can Use: VW 113-905-205AL, Bosch 0231 146 101, VW 043 905 205 ZB (Mexico) (See Note Below)
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 059
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC @ 800-950rpm w/strobe and w/single vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum: 8-12deg Adv; Centrifugal: 7-12deg @ 1600rpm, 20-25deg @ 3800rpm
NOTE: Volkswagen (with Bosch's help) now makes this distributor in Mexico and is available brand new and ready to install. Please click this link:Beetle (Puebla, Mexico) With Points Distributor to view the specs.
Beetle 1974 * 1600 Calif Auto-Stick Trans
Distributor: VW 043-905-205D, Bosch 0231 176 033
Can Use: VW 113-905-205AH, Bosch 0231 167 053
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 118
Spark Plug: W8AC
Beetle 1974 * 1600 Federal Auto-Stick Trans
Distributor: VW 043-905-205A, Bosch 0231 170 036
Can Use:
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 059
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC @ 800-950rpm w/ strobe and w/single vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum: 8-12deg Adv; Centrifugal: 13-15deg @ 2300rpm, 22-25deg @ 3800rpm
Beetle 1975-1979 * 1600 FI Manual Trans
Distributor: VW 043-905-205H, Bosch 0231 176 044
Can Use:
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 114
Spark Plug: W8AC
Advance/Retard Range: Vacuum: 5-8deg Adv, 11-13deg Ret; Centrifugal: 6-12deg @ 1500rpm, 20-23deg @ 3500rpm
Beetle 1975 * 1600 FI Auto-Stick Trans
Distributor: VW 043-905-205J, Bosch 0231 176 053
Can Use:
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 126
Spark Plug: W8AC
Timing Set At:: 0deg TDC @ 800-950rpm w/strobe, vacuum hose(s) connected.
Advance/Retard Range: Vacuum: 8-12deg Adv, 6-8deg Ret; Centrifugal: 6-11deg @ 1500rpm, 20-23deg @ 3500rpm
Can Use:
Condensor: 02 074
Rotor: 04 033
Cap: 03 010
Coil: 00 012
Vacuum Can: 07 126
Spark Plug: W8AC
Distributor: VW 043-905-205 ZB, Bosch 0231 170 034 (Mexico)
Can Use: VW 113-905-205AL, Bosch 0231 146 101, VW 043 905 205, 0231 170 034 (German)
Notes: This is the Mexican manufactured version of the original 043 905 205 Distributor, originally used on 1974 Federal Manual Transmission Beetles. This was used on Mexican production Beetles early on before they switched to Electronic Ignition (year periods are unknown, but I believe it was sometime in the 80s). This distributor comes with a Single Vacuum Can is essentially a carbon copy of the original German made model. It uses all of the same components of the original German Distributor except the Condensor as noted below. Timing specs are the same as well and have not changed.
This is THE Distributor to use on your stock engine w/Solex 30PICT-3, H30/31PICT Series or 34PICT Series carbureted 1600 Beetle thru 1974 (75-79 w/Carb) & Type 2 1600 thru 1971. It is NOT recommended for use with the 30PICT-1 or 30PICT-2 because the vacuum signal is incorrect for the vacuum assist to work properly. This Distributor is essentially a "009" with a Vacuum Advance Assist to help prevent hesitation in all of those Stop-n-Go situations in city traffic. The Mechanical Advance takes over out on the highway to provide the most excellent Advance Curve in all sorts of engine loads. If you're running an original Dual-Vacuum Distributor on your Beetle 71-74/Type 2 1971 application(s), you will need to cap off the "Retard" Vacuum Port located on the rear of the Carburetor. Available new from a number of VW Parts Suppliers.
This distributor is similar to but should not to be confused with the "Bruck Germany" Distributor being sold by a number of outfits. In actuality, this is a Chinese knock-off of the Bosch Mexican "034" and the reliability of this distributor has not yet proven itself IMHO. Let the buyer and user beware!
Condensor: 02 054 (German model used 02 074)
Rotor: 04 033
Cap: 03 010
Vacuum Can: 07 059
Spark Plug: W8AC
Advance/Retard Range: Vacuum: 8-12deg Adv; Centrifugal: 8deg @ 1300rpm, 10deg @ 1600rpm, 15deg @ 2500rpm, 20deg @ 3000rpm, 21deg @ 3500 to 4000rpm
Note: The Advance ranges shown are courtesy of Richard Atwell who performed a test of this distributor's capabilities on a Sun Distributor testing machine. You can view the appropriate advance graph images at the following links (click on them): Vacuum Advance, Centrifigual (Mechanical)
Beetle (Puebla, Mexico) With Electronic Ignition thru 2004
Distributor: VW BAA-905-205C, Bosch 9237 040 030
Note: This is a Mechanical Advance Only Distributor equipped with an Electronic Hall Ignition. There is some information available, more to come!
Distributor Hall Sender: UNKNOWN
Ignition Control Module: VW 191-905-351B, Bosch 0227 100 142, Meyle 100 905 0005
Cap: 03 212 when using Original Beru Ignition Wires
Note: 03 010 cap is interchangeable (using 09 001 Ignition Wires)
Coil: VW BAQ-905-115B (Echlin), Bosch UNKNOWN
Ignition Wires: See Distributor Cap & appending note above.
Spark Plug: W8AC
Timing Set At: 10 Degrees BEFORE Top Dead Center @ 850-900rpm (Thanks to Cliff Crate, owner of 92 Mexi-Beetle)
Snoopy Feb 6 '18
VW Models Equipped With "009" Distributor
Distributor: VW 126-905-205, Bosch 0231 178 009
Chrome Version: Bosch 9230 081 094
Can Use: 0231 178 001, 0231 178 003, 0231 129 010, 0231 129 019
Note: The 001 distributor has VW# 126-905-205 stamped above the Bosch number and is primarily used on industrial engines for constant high rpm use. The 003 was the successor to the 001 and 009 succeeded the 001 or 003 as per Bosch microfiche. The 001 or 003 Looks identical to the "009". I have a 001 and 003 in my "permanent" distributor collection (somebody's gotta have a hobby!).
Condensor: 02 086
Rotor: 04 033
Cap: 03 010
Timing Set At:: Most applications - 5 to 7.5deg BTDC Static. Full advance should not exceed 32 degrees at 3000rpm with stroboscopic timing light. Here's a couple of links dealing with this subject:
Ken Hooper's Timing The Bosch 009
Ken's Buggy Barn Timing A 009 Distributor
Snoopy Feb 6 '18
Models Equipped With "050" Distributor
Distributor: Bosch 9230 081 050
Points: 9232 081 044 (Can use 01 030)
Condensor: 9231 081 465 (Can use 02 086)
Rotor: 9231 081 628
Cap: 9 231 081 413
Here's a bit of Info on the "050"
Andy McKinley's "050" Distributor Reviewed
Snoopy Feb 6 '18
Rotor: 9231 081 628
Cap: 9 231 081 413
Snoopy Feb 6 '18
Rotor: 9231 081 628
Cap: 9 231 081 413
Snoopy Feb 6 '18
Type 3 Models Using VW 311-905-205Q, Bosch 0231 137 033
Distributor: VW 311-905-205Q, Bosch 0231 137 033
Models Installed On: This was VW's primary replacement Distributor for 1500/1600 Engines on Type 3 65-67 w/Dual Carburetors.
Condensor: 02 069
Rotor: 04 006
Cap: 03 001
Vacuum Can: 07 017
Spark Plug: W8AC
This topic is sticky
