1.9L waterboxer engine (83-85) Rebuilt 00 exchange (I have two (2) built up) | Forum
Topic location: Forum home » General » For Sale
bear
bear Oct 5 '17
Engine has new Main, Rod, cam bearings, oil filter, oil pump, waterpump, front & rear oil seals, rings, spark plugs, lifters & cam and oil pressure sensdor. Re-furbished parts, P/L's, Case washed and checked, heads re worked, Crankshaft polished, Crossover pipe installed under the timing pully, alternator bracket installed, oil breather installed, flywheel faced and installed, end play set. Contact Phil (bear) at 1-864-859-8256 205 Old Stagecoach Rd. Easley, SC 29642 bearsvw2000@yahoo.com
The Forum post is edited by bear Oct 11 '17
