Chirping engine | Forum
Snoopy Jun 22 '21
Here's a new one to everyone I've asked....
I rebuilt an engine bottom up.  Run it and after the lifters pump up, you hear a chirp like when the battery is dying in your smoke detector.  It is not cyclical and occurs at low idle.  You can't tell where it is coming from at all.  We have it running out of the bus and can stand on left and it sounds like the right side, if on right it sounds like the left side.
We finally figured out that if you disconnect the number 1 spark plug wire, it stops but as soon as you touch the plug wire back the spark plug, it chirps.  We replaced the plug and the wire and still the same issue.
Any ideas?
Snoopy Jun 25 '21
We pushed compressed air through the spark plug hole and found a small air leak between the head and the cylinder. It didn't chirp but we think it's the issue. The head would not tighten any more so we can't check. I ordered new heads and new pistons and cylinders. We're hoping this solves the issue. I'll update afterwards
