I will have to see if I can find it, it all got boxed up a few months ago and is in the barn somewhere, everything got shuffled to make room for some other stuff so not sure exactly where it is now. But basically I have 2 of the 86-91 clusters to some degree, both main housings have at least 2 of the 4 main mounting tabs broken off, and at least 2 or 3 of the screw holes where the tach or speedo mount are broken off. I can't imagine going to the trouble to switch all that stuff for one of those. I have one speedometer, about 187k I think, 2 tachs, no idea if they work or not. I think 2 gas gauges, no temp gauges, and a couple of beat, leaky LCD clocks. (best source for clocks is a MKII Jetta/Golf from a junkyard, still pretty easy to find & cheap. Likewise some of the other stuff I'm told will crossover too, like the temp gauge, even tach and some other stuff.) Basically if you have a couple pieces not working on yours I can probably help you out, but if you need the whole thing probably not much I can do with that...
