Here are some things I have tried:
pulled all wires from light switch
pulled all wires from emergency flasher
pulled plug off ignition switch
pulled all wires off coil
This happened sometime after I replaced the foam seal around engine, but I don't know if related to my issue.
Yes they do go off when I disconnect the neg. battery terminal... Anyone had this problem? H E L P !
